RE: How well will this engine work
Hi here is the specks on this plane. Thinking about using poly u for covering whitch will make plane littie heaver. I have a F6F Hellcat with a G20 in it it fit fine under the cowl. Also where can I find a good price on retracts for this plane I found a few forums on this plane for building help but none with a gas engine. I wat told that this plane was tail heavy with glow engines, instead of adding lead I will just add little heaver engine.
Thanks for all the help
Engine Specification
Displacement: 20cc
Bore and Stroke: 30mm X 28mm
Total weight: 2.38 Lbs, not including ignition battery pack
Walbro type carburetor
Power: 2.2 HP@ 7500rpm
RPM Range: 1500-9800 rpm
Recommended Props: 16X6, 16X8, and 18X5
Ignition: Auto Advance DC-CDI Electronic, made by RCEXL with CM-6 MINI Plug
Fuel:Pump gasoline and 2 stroke oil
Overall width: 6.00"
SPECIFICATIONS
Stock Number: TOPA0135
Wingspan: 63 in (1600 mm)
Wing Area: 713 in² (46 dm²)
Weight: 8-10 lb (3630-4540 g)
Wing Loading: 27-32 oz/ft² (82-98 g/dm²)
Fuselage Length: 55 in (1400 mm)
Engine Required: 2-stroke .61-.90 cu in (10-15 cc) or 4-stroke .91-1.20 cu in (15-20 cc)
Radio Required: 4-7 channel w/4-8 servos
