RE: Is all thrust the same?
Thanks Bob and Harry for the very useful info.
If ram effect is negligible at the speeds we operate, then it would seem from the above explanations that if motors A and B have the same static thrust, but A has a higher exhaust velocity, then A would have more available thrust than B at the upper end of our operating range - say 200 mph forward air speed (if you fly in the U.S.). Is that a generally true statement?
