RE: another darn ryobi post (ryobi performance modification, analysis and comparison)
Frank can make whatever you want for rings. On a two ring piston, I usually use the stock ring in the second groove, and one of Frank's in the top groove.
A hone won't work very well on most of these small engines, as it will hang up in the transfer ports, and ruin not only your hone, but probably the cylinder as well. If your cylinder is so bad it won't clean up with some 400 sandpaper, you should probably just get another cylinder or engine.
AV8TOR
