RCU Forums - View Single Post - FASST signal voltage compatability
Old 03-03-2009 | 01:11 PM
tailspins's Avatar
tailspins
My Feedback: (7)
Default RE: FASST signal voltage compatability
Mike
When you set your CG did you draw a string line from wing tip to wing tip and then mark the spot at the fuse? I "hang balance" my models so I always need a reference point at the fuse rather than at the wing tip.
This was my last winters project and how I set the CG.
