RE: wren 54 help please !!
Not sure what a PT wheel is but all you should have is a compressor at the front and a turbine wheel at the back. If these are the same parts that are on a normal turbojet and if it is reaching 160,000 rpm there should be around 14 lbs of thrust comming out the back end. Can you post a pic of the front and back end of the turbine
