RE: Extra Extra V2 - Build thread
Here's the start of the build pics...
PLEASE READ ALL THE WAY THROUGH THIS BEFORE BEGINNING. ESPECIALLY PAY ATTENTION TO THE SUGGESTED MODIFICATION SECTION.
First you start by gluing the sides together. NOTE: If you are chose the laser cut ply sides the lasers kerf will require that you use a gap filling glue (i.e. gorillla, epoxy, etc.) The sides are dovetailed and made such that they will self align and only go together one way. Once the sides are done add the 3/8" x 1" dowels in the wing bolt locations on the LEFT SIDE FUSE (add these only to the left side!). NOTE: THE LEFT SIDE IS THE SIDE WITH THE SMALLER CUT OUT IN THE MOTOR MOUNT AREA. Use a square to make sure they are perpendicular to the fuse sides.
