RE: Extra Extra V2 - Build thread
Now the fun begins...former installation. These go in from the tail forward. Once you reach the rear of the wing saddle stop as the next step will be the tube and motor mount installation. If you have the CNC fuse version then make sure you lay all the formers out. They only go in one place but a few are very close in size if you don't pay attention. The laser version are all marked and will match the codes on the fuse. We may label the CNC versions as well later on.
On this step just make sure the tabs are all the way in and you use your square with some quick CA. The process is very fast and accurate this way.
