RE: inverted to normal flight maneuver question
i would try to give the elevator as much down throw as possible, maybe move the cg back a little
i have a gws slowstick and brushless that overpoweres the plane 2:1
the plane hates doing inverted outside loops. i have to give it so much throttle that the motor's torque affects the plane. but it helps if you dive a little.
if you cant do it its prob not you, its the plane
