What about mixes during harriers?
Do you guys use mixes (i.e. elevator to rudder to correct for coupling) while doing harriers?
On the simulator I can do these in my sleep. The real thing is much harder. I'm interested to see the above comments about not using too much elevator. I think that might be my problem (or one of my problems at least). I start out okay but end up in a "pop-up" where the plane's almost verticle.
I'd guess that the mixing will keep things smooth as my plane tends to pitch to the belly a little with the rudder.
Thanks........Mark
