Originally posted by 3D'nPat
.....The pop-up sound like your using too much elevator and maybe too little rudder.
........ are you unintentionally pulsing your throttle when you move the rudder stick? That would indicate there is too much down thrust.
....... Also makes me wonder what you are flying?
Thanks Pat!
Next time at the field, I will definately give the "Less elevator, more rudder" at try. After reading this thread including your advise, I'm thinking this will help a great deal.
I'm flying a 33% Aeroworks Edge. It has a little bit of coupling to the belly but no roll coupling what so ever. I'll fly a straight and level/cut throttle test to see if there is too much down thrust.
Thanks again...........Mark
