[quote]
[/quoteOk if i figured this correct it is just electronic or manual mix dependant on which radio you use. So i am assuming that using my dx6i or a good digital radio is the better option. ]
nsane, If your going to go "EMS" and use ECCPM an the caliber you have the option on the caliber series to install the after marker EMS mixing linkages. On my caliber 5 It's an option on the caliber 6 it comes stock now I don't know about the caliber 4, or the 30 like you have if they ecept the upgrade kinkages I would highly recomend itif it does!! you can purchase the upgrade for around $35.00 @
www.rcheliworks.com or stright from kyosho america. The benefit of the upgrad is having a nice push pull linkage set up!, crisper and more degree in overall cyclic and collective throw! Good luck ECCPM and and PCM 2.4 g's is the only way to fly!!!! Buy a DX7 thy are very resonable and you can get a much better ECCPM set up out of it!!! like 5 point throttle and pitch curves,thre program mixes,gyro sense page,ec,ect......[8D]
