RE: Hyperion Z5025-22
This is the wire area, you can see clearly the guel inside the hole.
The wire man also tell me that this motor can not be back mounted, it much be front mount, when motor become hot it will loose and if back mount it will move forward, so this design is bad.
So for me I dun know it's because of my luck is bad or the design problem????????
