RCU Forums - View Single Post - Help
Thread: Help
Old 03-05-2009 | 09:08 AM
tkilwein's Avatar
tkilwein
Default RE: Help
If you flood your engine with a rear carb and carb is inside fuse you may dump a little fuel inside.
Make sure you have a seep hole and seal up the wood.
Minor issue.
The rear carb may be a slimmer setup for narrow fuses. This may help with some warbird fuses.
The side carb may require a extra side hole in the cowl.
