RE: Laser lizard???
I've gotten three sets of wood from Laser Lizard.
Ziroli Stuka
Ziroli SBD
Ziroli Zero
The kit cut for the Stuka wasn't all that good. Several parts (that were supposed to be laser cut) were missing, some were the wrong size and some just didn't match the plans at all.
The SBD kit is excellent. I have NOTHING bad to say about it. The wood is cut but not burned, the parts all match the plans perfectly and everything is there except for the strip and sheet stock.
The Zero kit is a mixed bag, for the most part the laser cutting is very well done, but some it was burned, causing the ply to bubble sap at the cuts. All the pieces however were there and did line up with the plans. I would have just called Laser Lizard to get the ply parts re-cut, but I got this kit second part.
On a scale of 1-10, I would rate Laser Lizard a high 7. I've seen better, but I've also seen a LOT worse.
