Another Snap Roll Switch Question
Hi Mr. Baxter,
I posted a note several days ago because I could not get both elevator servos to move when I hit the "Snap Roll" switch (the same thing happens with my rudder servos only one moves with the switch). I had programmed both elevator servos to work together using a mix. You suggested to put both servos tied to the same stick. I tied them to the stick in the function menu.
Still, when I hit the snap switch, only one servo moves. When I move the stick both servos move as you would expect. I need to be able to set different a 17 point curve on one of the elevator servos so the the movement of the the elevator halfs match.
Selecting "Ailevator" tail type might fix the snap switch issue for the elevator, but the second rudder servo needs to move when the snap switch is activated.
