RCU Forums - View Single Post - JetJoe OWNERS thread
Old 03-05-2009 | 05:21 PM
  #1946
Gordon Mc
Default RE: JetJoe OWNERS thread
ORIGINAL: bukeym
Hi everyone,
Attached you can see the photos of the combustion chamber of my JJ1400. I am experienceing high temp problem at high RPMs particularly after 130K. I have checked everything: 1. Balance is perfect 2. vaporizer tubes tested with propane not much difference 3. Startup perfect temp not over 450-500 C. 4. Bearing conditions are OK. 5. Compressor clearance is even perfected with sheets of hysol layers.
So I believe there is only one problem left: Poor vaporisation!... Am I correct?.. I see that the vaporiser tubes are way too short and away from the combustion front cover..I would appreciate some input. Can I find vaporiser tube circle similar to MW 54 ?. Does anyone have spares or any contact for supplying?.
Yes - you should be able to buy spares from the Turkish JetJoe agent ... according to http://www.jetjoe.com/htm.php?nowmenuid=9648 he is:
Turkey:
Mr. Murat Bukey and Cumhur Guvenc
Sehitler Cad 18/3 Alsancak Izmir 35230, Turkey
Tel: +90 532 615 07 33
Web: www.gjet.net
Email: [email protected]
Hope that helps !
Gordon
