RCU Forums - View Single Post - are Extras more tricky then Edge 540?
Old 03-06-2009 | 08:27 AM
rmh's Avatar
rmh
Default RE: are Extras more tricky then Edge 540?
well boyz- The early Extra and the EDGE are really about the same design
and you can cogitate the sweep factors till the cows come home
But
th lightest one with the most power will be the best
ther isn't 2 cents worth of difference otherwise.
Size really doe not matter eithe
Having done the 33% series of H9- aerobats- the lightest ones were the best
but I liked the CAP and the EDGE I had because I had the power jacked up in these. (not the weight -the power .) Going down . We redesigned all the flying surface on one EXTRA - thinner n lighter sections -it was same planform but the reduced weights really showed upto IKARUS models -we again saw the same thing in5-6- ounce flyingweights .
40% stuf? again -the same - the light one
27% ?same again
The corker is in full scale aerobatic types
same thing
th best performers have highest power -lowest relative weight
ID:	1151379   Click image for larger version
ID:	1151380   Click image for larger version
ID:	1151381   Click image for larger version
ID:	1151382   Click image for larger version
ID:	1151383   Click image for larger version
