ORIGINAL: BirdofpraY
well why would gaspar need a forum, they work just perfict and if it doesn't... Well it must not be Gaspar... lol
Having read a lot of posts on the Xiroy site and Gaspers earlier ecu site, many turbine users fiddle with their ecus, change various settings to get better running[:-], then wonder why their turbine is not running right, if at all. Others reverse polarity (should be impossible for a competent user) and cook the boards [>:]and just want an answer. Others you'd not trust with a box of matches and most just have a real problem with their fadec, mine was a failing battery causing start up problems as the starter drained the power. Gasper analysed, mapped out sequential tests to identify the underlying problem. Once fixed, worked a treat and I have four of them which operate faultlessly.
You don't miss support though until you really need it.
Paul
