RE: Serious Needle Tuning problems.
I dried out everything too out the plug replaced it the engine started fine on factory settings but I think the Idle screw is still messed up or something is wrong, the engine just wants to take off. I had the LSn set a little bit to where it was like you tap the throttle and it went but sometimes would like speed up and hit like really high rpms or sometimes id go to gun it and itd bog out. the engine is like on the fritz i just cant put my thumb on why this thing is running so screwy. I mean it should be cake. you set the LSn and HSN to factory and basically all yous hould have to do from there is turn clockwise to make it run better but im all over the place! Need some sick help lol
