Radio channels
Newbie, so have pateince with the question.
I noticed people talk about using a seperate servo for each aileron.
Wouldn't one servo be enough by setting it up so as one aileron is lifted the other side lowers.
Is it for redunacy? Can use a smaller servo if only pushing one aileron? Safety?
And if you did use two servos for ailerons, is it possible to run them off the came channel? Can you run 2 seperate channels off the same contol input (stick)? What would a Y-Connector be used for?
Sorry if this has been covered before. If it has, just point me to the link and I'll go look at it.
