Thank You
OK. I understand the one servo and y-harness but the two channel thing is whipping me.
If you control each aileron sepertely, what are the control inputs for each one from the Xmitter?
I dont fly yet, but am learning so bear with me.
If I recall the Xmitter input to the aileron servo is the left stick (Right and left) which would be transmitted on CH1. Can both servos (each servo having it's own channel) be controlled from this one input? Is this part of "programming" the box to allow this?
If this is true, then that is pretty darn cool!
My only exposure to a servo setup is a PICA Spitfire (1/6) which only had a 1 servo setup (centerline) for both ailerons. It seemed to work fine.
Thanks!!
