RE: RF interference
Metal to metal is only a problem if there can be lots of movement between the two items. A tight joint with no play seldom exhibits a problem. If that can not be obtained, a flexible jumper wire securely attached to each part which electricaly shorts them together will keep any rf from being generated.
