Moki Ignition (same as RCS 1.8) Question
The instructions say: "If you resite the integrated ignition system from the rear housing of the front induction engines to, for instance, the fire wall, then an earth-strap must be connected between the PCB and the motor itself (the igntion fixing bolts act as earth-straps as delivered)."
Is the black wire the "earth-strap"? Or do I need another wire?
