RCU Forums - View Single Post - control throes
Old 03-08-2009 | 10:48 AM
wzak29's Avatar
wzak29
Default control throes
Is this correct it seems like very little movement?
(I built the sport wing)
“SINGLE RATE TRANSMITTER
The following throws are for a transmitter that does not
have Dual Rates.
PT-40
ELEVATOR 1/4" up 1/4" down
RUDDER 1/4" right 1/4" left
AILERONS 7/16"up 1/4" down
Note: The balance and control throws for the PT have
been thoroughly tested and represent the settings at
which the PT flies best. Please set up your PT to the
specifications listed. If, after a few flights, you would
like to adjust the throws to suit your taste, that’s fine.”
