ORIGINAL: TedMo
Chuck: the nice feature of dual rates is your ability to set the maximum throws the way you think they should be then reduce them by about 1/2 for low rate. That should give you the margin of safety to fly successfully on the maiden.
Yes, I know. Been using my radio for quite a while.
On the plane I mentioned, I actually set the low rates at 40% of the high and the elevator and aileron were still too much.
My point to the original poster was that too much throw would not be a good thing. In my example I managed to fly the plane safely because I've been at it a few years and I knew to relax and be gentle on the sticks until I could land and make the needed adjustments. A complete beginner might not be so lucky however.
That bring sup another good point for beginners... until you are absolutely comfortable with your skills, always let someone with more experience maiden the airplane. There's no worse feeling than losing a nice plane on the first flight.
