RCU Forums - View Single Post - Inverted Engine
Old 03-08-2009 | 09:47 PM
twick
Default RE: Inverted Engine
I had pretty good luck with an inverted engine after I made a loop in the fuel line.Come out of the tank and route the hose up as high as you can before going back down to the carb.Doing that solved all my running problems. Now if i can just find an easy solution to keep from flying into trees I'll be happy.
