RE: FS One by Hangar 9
Hi Katman,
I think I saw one of your quick works of art on the RCG post. Can you tell me what brushes you use and where you found the patterns that you used? It looked pretty nice. Regarding the trading of setup information for aircraft, the answer to your question is yes it can be readily shared. The sharing of setup and tweaks for the Rex-450 heli is an example. There's probably a setup file for each aircraft that be copied across just like the images.
Dave
