RCU Forums - View Single Post - need help setting up 12x......
Old 03-08-2009 | 10:59 PM
Dustin Buescher's Avatar
Dustin Buescher
Default RE: need help setting up 12x......
I may be wrong, but I think when you disable aux 4 it will drive the servo to the knobs 12 o'clock position regardless of where you had the aircraft tracking straight. you should have just used sub trim on the aux 4 channel if you want to have it disabled...
I like to use the small trimmers above the gimbles, they are not easily bumped like a knob.....
