ORIGINAL: w8ye
I like the computer radios for the exponential capability where you can make the controls real smooth at the center and yet have a pretty good total deflection
I also like separate aileron channels for each servo
I like the ability to feed a little rudder in with the ailerons and a little elevator in with the flaps
I like the ability to slave a second servo in with the elevator servo so I can run two servos on the elevator and program the slave servo's direction and total travel
I do fly real airplanes and understand exactly what you are saying here Whisky Eight Yankee Echo. Sounds like you know exactly what you are doing. Like I said i don't expect to be flying any flap or flaperion planes. The mixing of the rudder and ailerons sounds like something I am intrested in. That will keep the plane turning instead of slipping making my r/c experience all the more better. Does this mixing require more channels?
