RE: MiniMental is back once more!! Speedmaster .21
i have nothing mounted, im just about to mount the engine now. will 1/2" clearance between the engine and stuffing box be ok or should i have more/less?? how far forward should i mount the engine? Should i mount it so the carb is underneath the deck or further forward.
As for the shaft, i'll probarbly use an angle grinder.
only thing i need to know now is clearance between engine and tube and how far forward the carb should be.
Aidan
