RCU Forums - View Single Post - Need help in my first low wing!
Old 06-12-2003 | 05:18 AM
faisalk
Default Need help in my first low wing!
I just bought my first low wing plane. The elevator(not the horizontal stab) was in 2 parts to be joined by a metal rod so that they move simultaneously(since the control horn is only on 1 elevator and not both) now the problem is that when one elevator is in neutral the other one is slightly off neutral. I was wondering if this will create a huge difference or not? the problem is that I cannot fix it because to fix it I will have to cut the hinges and take out the metal rod which is epoxied. I want to know if it will make a big difference in flying or not?
