RE: Brison 6.4 question
thevirginian, rcdude7 has offered solid advice . Follow the instructions from C&H and set the timing by adjusting the length of the rod . I have 2 Brison 6.4's and the rods are not the same length . A static length check does not insure correct timing ,it has to be checked and adjusted. I also checked my 3.2 engines and none of them are exactly the same either.
