Flex Shaft Modifications
I purchased a prop flex shaft from Aeromarine for the Thunder Cat. It does not have a 'flat' machined in the prop shaft like the flex shaft that came with the Thunder Cat for the prop drive dog collar set screw. Has anyone modified such a drive shaft and if so how did you do it?
