Servo operating on switch on.
I have a problem with an uncommanded servo operation on my Fly Eagle Rafale. When I switch on the Tx & Rx, the servo operating the UP3 valve moves to the gear up position, then back to where it should be. This would not be good if the jet is sitting on its wheels at the time. At some point, I am sure to forget & trash the gear doors. None of the other servos act in this way.
I am using the 2.4 Spectrum AR 9000 Rx & a JR PCM9X2 Tx.
Is there a fix for this?
Being jet related I posted here, instead of the radio section.
