RCU Forums - View Single Post - Flex Shaft Modifications
Old 03-10-2009 | 08:23 AM
Square Nozzle
Default RE: Flex Shaft Modifications
Since the prop shaft is likely dead soft, you can file the flat on the shaft with the narrow edge on a flat file. Alternate method; if you have a high speed grinder (Dremel, Black & Decker, etc), use a cut off wheel and grind the flat.
