RCU Forums - View Single Post - Bungie Help ?
Old 03-10-2009 | 10:03 AM
rcmiket's Avatar
rcmiket
Default RE: Bungie Help ?
ORIGINAL: KingCobra
Mike, I'd like to hear the specs and tips on constructing yours. I noticed too that you have some postings on another bungee launch thread. In that one it looks like you've replaced the tops of the front vertical supports with cut open T's to extend the launch rails. And maybe give it a bit more vertical height? What prompted the modification? CC
The modified launcher was raised in elevation for a better launch angle. The foam was causing too much drag on launch so I went with the cut open T's, works great now no issues. I'm gather the specs and will have them up in a while. Mike
