RCU Forums - View Single Post - BH T-28 Assembly
Old 03-10-2009 | 11:39 AM
  #604
Warbird Joe's Avatar
Warbird Joe
Default RE: BH T-28 Assembly
ORIGINAL: balsabuster2003
ORIGINAL: Clay Walters
A 12 X 8 3-blade should be fairly equivalent to a 13 X 8 or 14 X 6 2-blade prop. Any of the three should be a good match to your Magnum 91 4-stroke as long as you've enough ground clearance and the 3-blade just looks good on the T-28.
Regards,
Clay
I tried a 14 x 6 two blade against a 12 x 8 three blade MAS prop on the bench. They ran within 50 rpm's of each other. They may run different rpm's at wide open throttle with the plane flying in the air though. Don't know.
Outstanding information Balsa. I just got a few 3 blades for $3 a piece at a swap meet and right now I can't remember if they are 12 or 13's. My question though is what about the two strokes. I have a Magnum 91 2 stroke.
