RE: Prop question.
You probably didn't get the vertical you wanted from the cessna because of its weight. I have an 11x7 apc on my mach 2 with a tt.46 and it will go vertically out of sight! The escapade is a similar plane to the mach 2 in its size and layout. Try all the props you got to find the one you like the most on the escapade.
