64mm Power Numbers...
I just hooked up a watt meter to the 64mm fan inside the Mirage. Using a 11.1v, 18c (I also tried a 15c with basically the same results), 1300 mAh battery I was getting about a 19 amp draw (185 watts) while running wide open. Just curious if anyone else has some number to compare these with???? Needless to say I'm pushing the 15c battery.. Guess I'll just baby it a bit more when I use it...
Fred
