RCU Forums - View Single Post - STATIC problem on Shuttle I think please help
Old 03-10-2009 | 07:44 PM
justbash's Avatar
justbash
Default STATIC problem on Shuttle I think please help
Hi All
Can anyone please help I have had my Shuttle ZTS for some time now but have recently changed my TX from FM to a 2.4ghz DX6i and the RX to a AR6200 since doing this the model has become a big worry to get in the air as the receiver keeps going into failsafe. If I bench test the problem does not exist even with all servos under load, the spectrum system requires the power to the receiver to be up to the job as this can cause the same issue I have gone to the extent of having two batteries in parallel and two switches but the same thing happens only when I spool up it doesn’t happen every spool up but about every 4th to 5th time the receiver just starts blinking. I believe it could be static build up zapping the receiver if this is the case what is the best way to get rid of the static.
