RCU Forums - View Single Post - a123 or nicad
Old 03-11-2009 | 01:32 PM
chuck l
My Feedback: (17)
Default RE: a123 or nicad
ORIGINAL: rotccapt
ok chuck on your dl are you having any problems with the a123 as your ignition since it is a 6.6v battery. the specks for the ignition say 4.8 to 6 max. i was thinking of using the fromeco wolverine switch and running 2 packs. also from what i am gathering 1100mah would be good for both packs?
I use to do what Walt is doing without any problems, but recently added a 1N5001 series diode in series with the positive wire for a .7 volts voltage drop for the ignition. I don't have any strong reason for doing it, maybe just for a little extra, extra insurance. Lot of people don't put in the diode and haven't had problems. Your call.
Chuck
