Set-up Tamjets Fail-Safe...
Hi guys
I am in the process of installing a Tamjets failsafe in a Weatronics rx and in a conventional receiver using 2 channels - one for gear doors and other for gear train.
How can I set-up the Tamjets gear fail safe with 2 channels. This device as a plug hole for gear servo and if you are using a sequencer (with only one channel) it is clear, but how about if you are using 2 channels as described?
Regards
Nuno
