RCU Forums - View Single Post - Set-up Tamjets Fail-Safe...
Old 03-11-2009 | 06:10 PM
ianober's Avatar
ianober
My Feedback: (12)
Default RE: Set-up Tamjets Fail-Safe...
I wonder if you could setup the Tam sequencer on a separate channel and then mix the channel with your gear switch so that if the Tam unit goes into failsafe then the mix would activate your gear? Have you called Tam yet?
