RCU Forums - View Single Post - Set-up Tamjets Fail-Safe...
Old 03-11-2009 | 06:31 PM
KC36330
Default RE: Set-up Tamjets Fail-Safe...
ORIGINAL: jetnuno
.....................How can I set-up the Tamjets gear fail safe with 2 channels.
You can't, they are single channel. IF both channels can be activated at the same time without delay/sequencing then you can plug the second servo into the AUX port on the unit, but if this were the case, you'd only need one valve in the first place
ORIGINAL: ianober
I wonder if you could setup the Tam sequencer on a separate channel and then mix the channel with your gear switch so that if the Tam unit goes into failsafe then the mix would activate your gear? Have you called Tam yet?
[sm=confused.gif] the Tam failsafe is activated via air pressure, has nothing at all to do with the radio failsafe system.
