RE: Set-up Tamjets Fail-Safe...
Thanks for the imputs.
In my F16 I have set up like the one in the attached photo. There are 2 servos driving 2 airvalves, in 2 different channels that have a mix with delay in my Futaba 12FG.
Also I was planning to install one in my F18 with Weatronics rx that as 1 channel in use but an internal mix in the Weatronics receiver with a master/slave with delay between each other.
From what I have understood the Aux in the Tamjets can be plugged to the doors and the rx plug to the gear. If there is a pressure drop the signal will be invoiced to both channels. The delay in the mix might retard the gear to open after the doors???????
Also I have the latest version of Tam's with firmware upgrade. This is not clear because from wht I understood from instructions is that I can operate brakes as long as I have gear down[&:][&:][&:]
Tam, some help would be appreciated
Regards
Nuno
