RCU Forums - View Single Post - Set-up Tamjets Fail-Safe...
Old 03-11-2009 | 08:03 PM
KC36330
Default RE: Set-up Tamjets Fail-Safe...
ORIGINAL: jetnuno
.............. If there is a pressure drop the signal will be invoiced to both channels. The delay in the mix might retard the gear to open after the doors???????
No the delay is via the transmitter it isn't the servos that are slowed, it's the signal the transmitter is sending to the receiver, when the failsafe feature of the gear reaches it's set low pressure the servos move at full servo speed.
Also I have the latest version of Tam's with firmware upgrade. This is not clear because from wht I understood from instructions is that I can operate brakes as long as I have gear down[&:][&:][&:]
if you have the brakes mixed to the gear (such as on the Flash) with the new firmware the servo will move within a set limit allowing the mix to turn brakes on/off, the gear switch has to be in the DOWN position for it to work. you can test it by pumping the pressure up till the gear will retract, with the gear retracted press the fill valve allowing air to escape, when the failsafe kicks in and drops the gear, moving the brakes will do nothing, flip the gear switch to DOWN and then the brakes should work. I've got the newest firmware on both mine and they both work as advertised.
when using the brake mix I've found one thing out, i have mine on my Flash set so when the failsafe kicks in it drops the gear and puts the brakes on, because of this when i power up the receiver with the transmitter in brakes OFF the brakes will not release till I've placed the brake switch in the brakes ON position for about 2 seconds, the failsafe unit boots then and will allow the brakes and gear to function.
