RE: T-34/85 Winter version with DX5e
Hi Phil changed my mine took a old pill bottle and cut it down to size with a dremel cutting wheel for the rear cover if you do this gearbox replacement make shore if you drill and tap the shaft that its level same with the T-34 wheel pins off just a little and the wheel will wobble .
Thanks Jimmy
