RE: Will changing the fuselage from square to round effect it's handling?
The two things I see changing the "feel" of the plane is the increased wingloading as mentioned before and less effective side area. The benefit of this would be that the model will be less affected by cross winds. The downside is that you be able to do knife edge manuvers as easily since you are basically reducing the side area of the plane...
