RCU Forums - View Single Post - Best 7 Channel
Old 03-12-2009 | 03:02 PM
BarracudaHockey's Avatar
BarracudaHockey
Default RE: Best 7 Channel
If you are looking at getting into giant scale aircraft with redundant receivers, the JR/Spektrum radios might not work. From what I have read on here, if you select your model and even though muliple receivers are linked to the transmitter, only the ONE that is for that model will respond. I don't know this for a fact but it is a question you may want to raise if you plan to run multiple receivers in an aircraft.
Thats wrong.
Well in the context you're using it it's wrong. You can bind two recievers to the same model memory for dual reciever installations.
It is true that once you bind a reciever its tied to that model memory until you rebind it, thats what model match is about, but you can bind more than one receiver to a model memory.
