RE: BH T-28 Assembly
Hi Guys,
Thanks for the quick reply and the nice welcome. I just snuck out with the wifes scale, it weights 8lb 6oz and i'm moving the motor foreward. Plus changing motor mounts to metal ones.
I'm still confused with cg105mm it balanced a little nose heavy.
I had to give it 17 clicks down elevator, added the weight and no trim and it flys OK.
It's not even close to the recommended CG, the CG now is 65mm..
Does this make any sence to you guys?
Carl
